ASeif
7 years agoIn-place boot on memory
Hi, I am using NIOS II with configuring it to execute in-place (not boot copier). I have a off-chip memory of 128Mb which the program is located there. Previously I use a off-chip memory of 16Mb. ...
Ahmed_H_Intel1
7 years agoHi Ali,
This is weird, are you sure this external memory doesn't have bad blocks? I recommend you change the serial flash controller settings to 64Mb and see if it will be working fine or not. If you still seeing the same issue then you might missing to update something in your design.
If you agree you can share with me a screenshots of the Qsys design and the Top level assignments.
ASeif
7 years agoHi Em_guy and thanks for your reply,
While programming I check the "Blank-Check" and no problem reported. The other point is that the memory I use is a new. Therefore bad block probably may not be the reason.
I attach the screenshots here for more inspection...
