12 years agoIn ALTERA Monitor it works, in Eclipse EDS it doesn't?
Hello people! I have followed the tutorial "Introduction to Qsys" from the ALTERA University program where a very small VHDL system is created plus an instantiation of the Nios II and some swit...
12 years agoPROBLEM SOLVED
Hello For those who have the same problem with me, the issue was that I haven't included the header files
system.h
altera_avalon_pio_regs.h
which describe the compiled Qsys system and let me access defined structures like my parallel ports as well as the function IOWR_ALTERA_AVALON_PIO_DATA that writes at the parallel ports. So the simple program described in the Introduction to the Qsys system tutorial:
# define switches (volatile char *) 0x0002000
# define leds (char *) 0x0002010
void main()
{ while (1)
*leds = *switches;
Should be in the Nios II EDS:
# include "system.h"
# include "altera_avalon_pio_regs.h"
int main()
/* Event loop never exits. */
while (1) {
IOWR_ALTERA_AVALON_PIO_DATA(LEDS_BASE, *((char*)SWITCHES_BASE));
return 0;
cheers
