15 years agoimpossible to boot ep3c25 from epcs16 - reset_vector problem ?
Hi, I am developing my first niosII design. It works well when I use a volatile programming file (.sof) but I have issues to program the fpga with an external flash. I use : - cycloneI...
15 years agoI was working on a coworker computer because mine was corrupted (vista, quartus& nios 9.1sp2). I have formated it this morning (w7 x64). I install quartus 9.1sp1, nios 9.1sp1 because after reading several thread I thought it had no bugs (1 is solved : http://www.alteraforum.com/forum/showthread.php?t=19765)...
I can't run memory test from on chip memory (not enough memory on fpga - ep3c25) and it doesn't work with sram memory. it is strange because it works with sram a few days ago. I will try without onchip memory at all, maybe I change something in the bsp editor. is there any documentation about linker ? I don't know what is the function of each field (.bss, .entry...) and I don't find any doc. maybe it could help to understand what occurs in sram.
