13 years agoImporting IP into SPOC builder
Hi all, I'm currently working on building an sopc builder and using on cyclone III target device. I have written a simple counter program to glow the LED's to familiarize myself with SOPC build...
13 years agoYes,Nios requires at least one avalon interface to communicate with my design. So i added few Avalon slave signals (which i don't need but its required for Avalon interface between Nios and My design) such as read_en,write_en,read,write,address. The HDL component file generated now has the signals that are present in my design which i have exported using the conduit interface. Then i instantiated this HDL component file in a top module and passed the Clk and reset signals. And yes thanks for the tip i used the same reset generated by system. The system works as expected.
Thank you.
