13 years agoImporting IP into SPOC builder
Hi all, I'm currently working on building an sopc builder and using on cyclone III target device. I have written a simple counter program to glow the LED's to familiarize myself with SOPC build...
13 years agoDid you add any other logic to the Nios CPU in the SOPC builder project? When compiling without the Nios CPU, what messages to you have form the SOPC builder generation?
I've never done such a simple system with SOPC builder, maybe it's expecting at least an Avalon interface somewhere... By the way you can still use a standard reset interface for your reset signal, even if you are using an external switch as reset. It will automatically create a reset input on the generated system.
