jwill24
8 years agoImplementing UPnP
I'm a student on an internship working on a small project by myself for work. However, I'm starting to feel that FPGA's using UPnP is the way to go with this rather than knowing the host PC's IP from...
SengKok_L_Intel
8 years agoHi Jwill, there is no UPnP solution from Intel FPGA as I can see. The Intel FPGA Ethernet IP offer the Physical and Data link (MAC) layer support as per the IEEE 802.3 standard. The UPnP should be implement above the Data link layer (per OSI model) and which is more software oriented design.
Here is the Intel FPGA Ethernet support centers that you can refer to:
Regards -SK
