20 years ago
Implementing UART communication
Dear all.
I need to implement UART communication for high baudrate (by interrupts).
My communication must be implemented as described below:
RECEIVING: rcv_buffer up to 255 bytes.
TRANSMITTING: AFTER receiving and checking all rcv_buffer , i send transmit buffer ( up to 255 bytes).
* delay between 2 incoming buffers is 100ms.
** RECEIVING must interrupt my running application ,after transmitting i must return to my interrupted state.
It is important to choose fastest communication.
Thanks at advance.
Alex.
    Hi Alex,
    This can be achieved with baud rates as low as 38400.
    This is typical ;-)
    It's not clear to me what you mean by this ... but you should have little difficulty
    handling the scenario you describe ... even with a very modest cpu clock.
    What is your question?
    --Scott
    Hi Scott.
    First of all thanks for the tips.
    I will be happy to get some Nios II IDE code example for same scenario.
    I want to understand how to use UART interrupts and to apply it in my application.
    Regards .
    Alex
    --- Quote Start ---
    originally posted by burdalex@Nov 25 2005, 01:11 PM
    hi scott.
    first of all thanks for the tips.
    i will be happy to get some nios ii ide code example for same scenario.
    i want to understand how to use uart interrupts and to apply it in my application.
    regards .
    alex
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11162)
    --- quote end ---
    --- Quote End ---
    Altera provide a driver for the UART, you don&#39;t need to worry about handling the interrupts from the UART. I suggest you either look at the hello world example or read the Nios II Software Developers Handbook.
    --- Quote Start ---
    originally posted by rugbybloke+nov 26 2005, 02:24 am--><div class='quotetop'>quote (rugbybloke @ nov 26 2005, 02:24 am)</div>
    --- quote start ---
    <!--quotebegin-burdalex@Nov 25 2005, 01:11 PM
    hi scott.
    regards .
    alex
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11164)</div>
    [/b]
    --- Quote End ---
    I have the same question of how to receive and transmit data using UART interrupt .I have read the Nios II Software Developers Handbook and driver for the UART, but I don&#39;t know how to use the API function of HAL,
    for example:
    1,how to declare the "fd" parameter of alt_avalon_uart_read (alt_fd* fd, char* ptr, int len)?
    2,Can I use the alt_avalon_uart_read (alt_fd* fd, char* ptr, int len) directly or use it throuth some other system function sush as read()?
    can you give me some example about it ?
    my Email is: [email protected]
