20 years agoImplementation of ISR in Nios 3.20 SDK
Hello Could somebody tell me that the following testisr.c program is correct. The ISR “irq_handler” is installed by “nr_installuserisr” procedure. The parametr “context” is set to pointer to &stab...
20 years agoHi chris01,
> Could somebody tell me that the following testisr.c program is correct. I don't have time right now to look more closely ... but you might want to consider making 'pst' point to a volatile structure (either make the struct volatile, or make the referenced object volatile) . Your interrupt may well be working fine ... but your main thread may never actually access memory after the first read. Regards, --Scott
