13 years agoimplementation of an arbitrary precision integer librar for usage in application code
Hello, This requirement is a part of my thesis and I was wondering have anyone occurred to do a similar task of this sort. I plan to implement NIOS II custom instructions that will accelerate...
13 years agoHello,
I figured out a user friendly library that can be moved easily to the NIOS II IDE build environment. Now in my application code I can use those library functions and see the timing analysis using the altera timestamp libraries. So I guess this question can be closed from my side. Thank You, Akhil Kalathungal
