13 years agoimplementation of an arbitrary precision integer librar for usage in application code
This requirement is a part of my thesis and I was wondering have anyone occurred to do a similar task of this sort. I plan to implement NIOS II custom instructions that will accelerate the speed of an arbitrary precision integer arithmetic (since parallel operations can be done in FPGA). As a comparative study I am asked to compare the speed of a normal arbitrary precision integer library function with the custom instruction. Say an ADDITION of 1028 bit + 1028 bit data. (This can be implemented in NIOS II custom instruction using verilog modules and can be called from the application C/C++ program using macros in system.h file). The same addition can be done in the application code using a multiple precision library as well. Issue is with respect to porting such a library to the NIOS II build environment. MPIR is such an arbitrary precision library which can be built with a Microsoft Visual C++ 2008 edition solution. Is there someone who is experienced in bringing such libraries to the NIOS II IDE build environment? If so that would be a big help. Any pointers towards this direction will be appreciated. Thank You, Akhil Kalathungal1 Reply
I figured out a user friendly library that can be moved easily to the NIOS II IDE build environment. Now in my application code I can use those library functions and see the timing analysis using the altera timestamp libraries. So I guess this question can be closed from my side. Thank You, Akhil Kalathungal
