20 years agoimplement interrupt by using custom component?
I want to implement interrupt by using custom component,fist I write a verilog HDL code;second ,i add it in Sopcbulider;at last,I write programme in IDE.
but i found that the interrupt can't happen. whether you can give me some suggest or example code on iterrupt,Thank all verilog HDL code(this is very small code ) module test( clk, reset, write, writedata, irq ); //inpnt signal input clk; input reset; input write; input [31:0]writedata; //output signal output irq; //Parameter parameter countval = 32'h0000_0010; reg [31:0]count; reg [31:0]ctl_reg; wire irq_enable; wire time_over; assign irq = irq_enable && time_over; always@(posedge clk or negedge reset) begin if(~reset) count = 0; else if(count >=countval) count = 0; else count = count +1; end always @(posedge clk or negedge reset) begin if (~reset) ctl_reg <= 0; else if (write) ctl_reg <= writedata; end assign irq_enable = ctl_reg; assign time_over = (count >=countval); endmodule ___________________________________________________________ NIOS IDE C code# include <stdio.h># include <io.h># include "system.h"# include "sys/alt_irq.h" void test_interrupt(void* context, alt_u32 id) { IOWR(TEST_0_BASE,0,0x0); // CLEAR INTERRUPT printf("Hello!\n"); IOWR(TEST_0_BASE,0,0x1); } int main() { int u; printf("Hello from Nios II!\n"); u=alt_irq_register(TEST_0_IRQ,0,test_interrupt); //alt_irq_enabled(); IOWR(TEST_0_BASE,0,0x1); // enable interrupt printf("Nios II!=%d\n",u); while(1); return 0; } ------------------------------------------------- I found it never interrupt ; what wrong with my work? I need helpNo RepliesBe the first to reply
