21 years agoImage Select Capability?
We want to implement "Image Select Capability" from Flash in "CPLD Config contrller " of custom Nios board. We have learnt the idea from P16 of AN346.pdf -- Using the Nios Development Board Con...
21 years ago1: yes. our current cyclone board has a custom loader CPLD design
that supports multiple images. the loader part fits into a EPM3128. 2: In the flash where you load the image from. You could also use the UFM of a MAX II (non ES device assumed) 4: Didn't delve into AN346, but if you want to support AS from an EPCS as well, the loader CPLD has to tristate all config outputs to the FPGA, or else they would contend. 5: This is covered in the datasheet. TDO,TMS up / TCK down / TDO open 6. Yes Cheers, Roger
