14 years agoIgor Mac, DP83848 and tcpdump
Hi all, could you somebody advice me with my problem ? I have design (in attachement) - NIOS2, SDRAM, ethernet (igor mac) with zImage and when i boot kernel and use ifconfig eth0 192.168.2....
14 years agoIf you mean the compile error -- it's not related to the FPGA/SOPC design. You should be able to build any of the user applications and libraries regardless of of the FPGA design.
If you mean your actual problem -- yes it's very likely it's the design, but if you are not using the latest version from Linux "nios2" branch then it could likely also be the software. I don't know anything about the Igor MAC though.
