11 years agoIgh EtherCAT master porting for Linux OS on CyconeV SoC
Hi, Does anyone could run well the Igh EtherCAT master for linux-RT of Cyclone V ? I got the linux-socfpga.git for downloading Linux-3.10-ltsi-rt. I already put the EtherCAT module and a...
10 years ago --- Quote Start --- Hi, Does anyone could run well the Igh EtherCAT master for linux-RT of Cyclone V ? I got the linux-socfpga.git for downloading Linux-3.10-ltsi-rt. I already put the EtherCAT module and application on the Linux-RT Helio board for Cyclone V. It could run well as communication cycle as 10 ms. And the Ethernet port will block when I use 1ms transmit rate. It seems that the delay of ethernet transmit/receive function is too long. Has anyone also verify the situation or anyone could point out the delay issue? --- Quote End --- Hi, Were you able to successfully use the TSE IP core for Ethercat master? How is the performance?
