11 years agoIf I want to put software program elf file into flash, do I need a flash controller?
If I want to put software program elf file into flash, then the system can load program automatically after power on, I think I need to add a flash controller in my qsys system, correct? Is Altera Av...
11 years ago --- Quote Start --- Altera supplies some libraries for writing the epcs/epcq devices from software if the avalon epcs controller IP is instantiated. One way to discover the correct elf offset is to run elf2flash with the --after option. --- Quote End --- Thanks. Do you mean "EPCS Serial Flash Controller Core"?
