21 years agoIDE Problems
This is a repost of a thread on the UC forum. I wanted to post it here also on the software forum. My problem is below this first post. Thanks, -Baycool ********************************************************* This is a custom board. I have taken everything out except for the Flash and SDRAM. It is actually a fairly simple system, flash, sdram, and an ethernet port. I don't use tightly_coupled_memory (have not familiarized myself with it yet), and my data cache line size is 4 Bytes, exception pointer is set to SDRAM. I am out of ideas. I also can not load the kernel into RAM from the IDE, I'm forced to burn the Flash each time I make a change. I get the following message from the IDE console. Do I have a JTAG problem? I'm using a USB Blaster "Rev B". Downloading 08000000 ( 0%) Downloading 08010000 ( 6%) Downloading 08020000 (12%) Downloading 08030000 (18%) Downloading 08040000 (25%)assertion "m_state == STATE_DEBUG" failed: file "nios2 debug.cpp", line 1695 Signal 6 Here is a copy of what I get when I launch the nios2-terminal. Most of the time I'm unable to log into the system, I usually get "Login incorrect." When I am able to log in, I usually get kicked out fairly shortly, and the system goes back to the login prompt. uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 1024 (order: 10, 16384 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory available: 128640k/131072k RAM, 0k/0k ROM (857k kernel code, 203k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80000860 (irq = 2) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 2 MTD partitions on "Altera NDK flash (AMD)": 0x00200000-0x00600000 : "romfs/jffs2" 0x00000000-0x00200000 : "loader/kernel" VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 52k freed (0x80f2000 - 0x80fe000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9 Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket Unable to create socket close on exec: : Bad file descriptor setsockopt: : Function not implemented Unable to bind server socket: : Function not implemented Unable to listen to socket /etc/issue www.microtronix.com June 2005 Welcome to Linux on the Nios II Nios2 login: Any ideas would be great, Doug ************************************************************* My reply: ************************************************************* Doug, Did you ever figure out your problem? I am also developing a custom board. I also get the mysterious error: assertion "m_state == STATE_DEBUG" failed file "nios2debug.cpp", line 1695 signal 6 What does this message mean? I just opened an SR with Altera, but have been stuck with this for a couple of weeks now.... My conditions are as follows: I get this error just by reversing the order of how I open my tools. If I open a shell to load my hardware before opening IDE I get the error. If I open IDE before opening my SDK shell I DO NOT get error. The result is reproducible with some of my boards. Other boards will hang with the message: nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) or not respond to further commands. I am in a jam because my boards have been manufactured and assembled and are ready for production , and now this error shows up. -Baycool I am using Quartus 5.0 and Nios II 5.0 with a Full License for both1 Reply
I just wanted to share with the forum, that I believe my error below: assertion "m_state == STATE_DEBUG" failed file "nios2debug.cpp", line 1695 signal 6 was caused by faulty ssram. I do have a custom board that still suffers with a Byteblaster like circuit, but So, in case any one has ruled out their JTAG connection or noise problems, do a robust on-chip test of your memory before doing a SW download. Thanks "slacker" for your assistance... -baycool
