22 years agoIDE FLash Programmer
I am having troubles with the Flash Programmer whne flashing the EPCS. The main problem is it isn't working. I have three different boards that all fail in the same way. Here is the console ou...
22 years agoA Nios2 with no outputs...? So, just what is it supposed to do? Does it have an EPCS peripheral? Sorry if I'm missing something obvious...
It just sounds like you have a Nios whose only purpose is to reprogram the EPCS; not a typical application. Quartus is supposed to eliminate logic blocks that have no outputs; theoretically, they have no effect on the system. Maybe it doesn't detect the hidden outputs in the EPCS peripheral?
