22 years agoIDE FLash Programmer
I am having troubles with the Flash Programmer whne flashing the EPCS. The main problem is it isn't working. I have three different boards that all fail in the same way. Here is the console ou...
22 years agoAfter four hours with our distributor's FAE, we found the problem. It seems there is a bug in SOPC builder and/or quartus. In our case, we have boards with an EPCS but no flash. It seems that if the Nios 2 on the target board has no outputs (as would be the case with no flash), the compiler optimizes away something. Anyway, the kludge is to add a PIO and send it to a virtual pin. This prevents the optimization from happening.
