22 years agoIDE FLash Programmer
I am having troubles with the Flash Programmer whne flashing the EPCS. The main problem is it isn't working. I have three different boards that all fail in the same way. Here is the console ou...
22 years agoSome additional info about my last post:
Initially I was using an FS2 ISA-Nios to do all flash programming through the IDE. I suspected that maybe this didn't work correctly, so I started using the USB Blaster. No luck. Same error as stated above.
