22 years agoIDE: Debug/Release settings do not change
I have a problem configuring my compilation parameters in NIOS IDE. I opened the window Project/Properties, selected Associated System Library on the left and clicked on its "System Library Proper...
22 years agoLooks like you may have hit one of the known issues which is documented in the errata.txt in the Nios II documents folder:
151588 - Changing active build configuration for a Nios II project - On the C/C++ build property page, the configuration dropdown box can be used to select the active configuration (e.g. Release or Debug). When the active configuration is changed, this does not automatically update the rest of the window containing the settings such as Compiler flags, optimization level, etc. The user must deselect then reselect a category (e.g. click on PreProcessor then General) to see the settings for that configuration. Hope that helps.
