21 years agoIDE compiler features?
Hi!
I have a question about IDE compiler features. I've made a board with CFI flash and Ethernet controller on the same tri-state bridge. CFI flash (data 8 bits) has dynamic alignment (A[0] = A[0]) and Ethernet controller (data 8 bits) has native alignment (A[0] = A[2]). But when I was tracing my board I've made error and put A[0] of Ethernet controller to A[0] of tri-state bridge. I've tried to describe ethernter controller as memory device (dynamic alignment) and created next structure for it in C: ....................# pragma pack(1) typedef struct _cs8900 { unsigned char DATA0L; unsigned char DATA0H; unsigned char DATA1L; unsigned char DATA1H; unsigned char TxCMDL; unsigned char TxCMDH; unsigned char TxLENGTHL; unsigned char TxLENGTHH; unsigned char ISQL; unsigned char ISQH; unsigned char PACKETPAGE_POINTERL; unsigned char PACKETPAGE_POINTERH; unsigned char PACKETPAGE_DATA0L; unsigned char PACKETPAGE_DATA0H; unsigned char PACKETPAGE_DATA1L; unsigned char PACKETPAGE_DATA1H; } cs8900;# pragma pack() volatile cs8900 *p =(cs8900*) CS8900_BASE; .................... but when I'm reading p->DATA0L or p->DATA0H there is always zero. When I'm writing there is OK. And in generaly it works. Maybe someone has any idea? Thx.No RepliesBe the first to reply
