19 years agoIDE 6.1 Memory Window
Hi, I installed Quartus 6.1 and all NIOSII tools. In IDE was some differences with older IDE version. For example memory window. But, when I load unsigned short buffer data 1, 2, 3, ..i, memory wi...
19 years agohi,
i dont think it is a real "bug" just an annoyance i experienced, too. and i gave up finding the option to "save view settings" - got somehow used to it by not using the ide anymore http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif btw, stepping thru your code may sometimes influence the results! (even with -O0) try using the 'nios2-elf-insight' debugger tool, my suggestion. regards, martin
