19 years agoI2C WRITE/READ problem
Hi all,
Some weeks ago, hippo help me sort out the OC i2c drivers, and it now works. I am now able to send commands via i2c. I was having a bit of problem when trying to do a sequence of write read. Herei s what I want: [Start] [Slave addr, W] [Device Param addr, 2 bytes] [Repeat Start] [Slave addr, R] [Receive 3 bytes] [No ack] [Stop] What I got is [Start] [Slave addr, W] [Device Param addr, 2 bytes] [Repeat Start] [Slave addr, R] <-- WRONG slave address (0x00) <------------ No data received due to wrong sequence. [No ack] [Stop] My code is based on the following: st linux (http://www.stlinux.com/docs/manual/distribution/distribution_guide6.php) ozlabs (http://ozlabs.org/pipermail/linuxppc-embedded/2002-august/008013.html) Can anyone help ??? The following is my code#include <stdio.h># include <linux/types.h># include <fcntl.h># include <unistd.h># include <stdlib.h># include <sys/types.h># include <sys/ioctl.h># include <errno.h># include <assert.h># include <string.h># include "i2c-dev.h"
# define MAX_I2C_MSG 2# define SIGMA_ADDR 0x34
int main(int argc, char **argv)
struct i2c_rdwr_ioctl_data work_queue;
unsigned int fd;
//unsigned short start_address;
int ret;
if ( argc < 2 )
printf("Usage:\n%s /dev/i2c-x \n",argv);
return 0;
//if ((fd = open(argv, O_RDWR)) < 0)
if ((fd = open("/dev/i2c-0", O_RDWR)) < 0)
printf("Error on opening the device file\n");
return 0;
//sscanf(argv,"%x",&start_address);
work_queue.nmsgs = 2;
work_queue.msgs = (struct i2c_msg*)malloc(work_queue.nmsgs*sizeof(struct i2c_msg));
if (!work_queue.msgs)
printf("Memory alloc error\n");
close(fd);
return 0;
char param_addr0 = {0x00,0x02};
char param_value = {0x00,0x00,0x00};
work_queue.msgs.len = 2;
work_queue.msgs.addr = SIGMA_ADDR;
work_queue.msgs.flags = 0;
work_queue.msgs.buf = param_addr0;
work_queue.msgs.len = 10;
work_queue.msgs.flags = I2C_M_RD;
work_queue.msgs.buf = param_value;
ioctl(fd,I2C_TIMEOUT,2); // set the timeout
ioctl(fd,I2C_RETRIES,4); // set the retries
//ret = ioctl(fd,I2C_RDWR,(unsigned long)&work_queue);
ret = ioctl(fd,I2C_RDWR,&work_queue);
if ( ret < 0 )
printf("Error during I2C_RDWR ioctl with error code: %d\n",ret);
close(fd);
return 0;
}2 Replies
I found out the problem.
The inlcude of i2c-dev.h was pointing to the wrong file. It should be pointing to
It now works.#include "i2c-dev.h" // This file has to be in /home/uclinux/uClinux-dist/user/lm_sensors/kernel/include/i2c-dev.h - Altera_Forum
you are right
