17 years agoI2C Master + BOA webserver (µClinux)
Hi guys, After the successful implementation a Boa embedded webserver using µClinux on the baseboard DBM_3C40, my idea is to use an I2C bus (interfaced through CGI/HTML page on the BOA server) ...
17 years agoIMHO it's not really good idea to work around the ways of the OS. While this will of course work with the current NIOSnommu system, I suppose it will not work with the upcoming MMU-enabled NIOS Linux. Moreover it's not portable at all regarding yet unknown Linux updates and other processors. The "correct" way of doing this is either create a decent device driver and to access I/O use the portable functions provided by the Kernel build system or - if you want to stay in userland - use UIO. In userland Interrupts are not possible. Of course the "official" way to use interrupts is doing a decent device driver. But I was told that UIO provides means to do a kind of "user-land-interrups" (I did not look into this yet).
(I just updated the wiki page http://www.nioswiki.com/operatingsystems/u...ux/compilehello (http://www.nioswiki.com/operatingsystems/uclinux/compilehello) ) -Michael
