17 years agoI2C interface on Linux (with MMU)
I have a few questions about I2C interfaces on Nios II on Linux with MMU. I found this thread http://www.alteraforum.com/forum/showthread.php?t=18441 (though forum search for "i2c" or "I2C" doe...
17 years agoI have verified: M41T0.
Here is the relevant output from boot:i2c /dev entries driver
rtc-ds1307: probe of 0-0068 failed with error -5
i2c-0: I2C OpenCores Bus Adapter, MMIO = 0x2120C00, irq = 9
i2c-0: Using 85000kHz clock source
And when I run i2cdetect: /# i2cdetect 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0.
I will probe address range 0x03-0x77.
Continue? y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I have verified in the part data sheet that the device address is 0x68. I finally got my hands on the Microtronix driver, but it is in a full linux distribution, for nios2nommu. I'm working on getting the relevant pieces transfered into the MMU build.
