21 years agoI2C Core and uClinux
Hi to all.
I want to integrate the Opencores I2C Core. How must i name the core in SOPC-Builder? When i want to build the kernel the error is: ------------- .... ---------------- drivers/i2c/.i2c-core.o.d: done. CC drivers/i2c/i2c-dev.o drivers/i2c/.i2c-dev.o.d: done. CC drivers/i2c/algos/i2c-algo-oc.o /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/algos/i2c-algo-oc.c: In function `i2c_oc_add_bus': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/algos/i2c-algo-oc.c:385: warning: unused variable `oc_adap' drivers/i2c/algos/.i2c-algo-oc.o.d: done. LD drivers/i2c/algos/built-in.o CC drivers/i2c/busses/i2c-oc.o /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: `na_i2c_0' undeclared here (not in a function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: initializer element is not constant /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:164: error: (near initialization for `oc_hw_0.base') /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: `na_i2c_0_irq' undeclared here (not in a function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: initializer element is not constant /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:165: error: (near initialization for `oc_hw_0.irq') /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: `na_i2c_1' undeclared here (not in a function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: initializer element is not constant /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:170: error: (near initialization for `oc_hw_1.base') /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: `na_i2c_1_irq' undeclared here (not in a function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: initializer element is not constant /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/i2c/busses/i2c-oc.c:171: error: (near initialization for `oc_hw_1.irq') make[4]: *** [drivers/i2c/busses/i2c-oc.o] Error 1 make[3]: *** [drivers/i2c/busses] Error 2 make[2]: *** [drivers/i2c] Error 2 make[1]: *** [drivers] Error 2 make: *** [_all] Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' ------------ end ------------ Bye Marco3 Replies
Hi Mabcom,
If you don't modify the kernel 1.4, you could add another I2C component in SOPC Builder! Then it will be OK! Best Regards! - Altera_Forum
Hi feiwu,
Thanks for your answer. But it doesn't work. The Linux I2C Driver from Microtronix will get two I2C Modules? i think the must be named like i2c_0 and i2c_1 ???? But in the nios2_system.h the are renamed to: # define na_i2c_0_avalonS 0x821208c0# define na_i2c_0_avalonS_irq 5# define na_i2c_0_ahbS 0x80000000# define na_i2c_1_avalonS 0x821208e0# define na_i2c_1_avalonS_irq 7# define na_i2c_1_ahbS 0x80000000 Is this right? I get the same error as above. Why is there the _avalonS added and who add it? The Kernel Build process? I'm a little confused.. Thanx Marco - Altera_Forum
HI Mabcom.
I think the name is not important, You could try to add 2 I2C component in SOPC builder. It should be OK! Best Regards, Feiwu
