21 years agoi2c bus not work i think ?
I have add the I2C opencores component in SOPC builder, add the logic in quartus and assigned the pins. copiled the kernell en filesystem. i have started the i2cset I get this on my consol...
21 years agoI have got the kernell build whit no error's.
This i think the solution is: When i add the component to the system in SOPC builder the name is "opencores_i2c_0" i rename it to "i2c_0" in the SOPC builder, the name in the nios2_system.h changes also. You must rerun SOPC an Quartus. Then i build the kernell en there where only error's on "i2c_1" and not on "i2c_0". I add a second i2c master to SOPC and also rename it to "i2c_1" then the kernell build;s wihout error's I don't have my kit with me so i will upload the kernell tomorrow and see if it is working. I it 22:00 hour at The Netherland now So it is just a name problem !!! I let you know if it is working tommorow
