21 years agoi2c bus not work i think ?
I have add the I2C opencores component in SOPC builder, add the logic in quartus and assigned the pins. copiled the kernell en filesystem. i have started the i2cset I get this on my consol...
21 years agoI get this
# i2cdetect
Error: No i2c-bus specified!
Syntax: i2cdetect I2CBUS
I2CBUS is an integer
With -f, scans all addresses (NOT RECOMMENDED)
With -q, uses only quick write commands for probing (NOT RECOMMENDED)
With -r, uses only read byte commands for probing (NOT RECOMMENDED)
If provided, FIRST and LAST limit the probing range.
i2cdetect -l lists installed busses only
Error: No I2C busses found!
Be sure you have done 'modprobe i2c-dev'
and also modprobed your i2c bus drivers#
