20 years agoI2C bus in vhdl file
hi! i would like to write a I2C file.vhdl (master) to communicate with several PCF8574 devices . I already wrote this library for PIC microntroller , without to use periperal and success...
20 years agotwo ways to do this:
1. in your vhdl file port ( .. .. sda_pad_i : in std_logic; -- i2c data line input sda_pad_o : out std_logic; -- i2c data line output sda_padoen_o : out std_logic -- i2c data line output enable, active low ); remark: "this is from opencores i2c master, see opencores.org" in Quartus graphic editor, add a "tri" component and BIDIR pin. connect sda_padoen_o --> tri.enable connect sda_pad_o --> tri.input connect tri.output to sda BIDIR IO PIN connect sda_pad_i to sda BIDIR IO PIN this one is preffered because you normally don't have tristate signals inside your fpga. IP cores are always connected together in this way. -- remark sda is open collector -- to write '0' to sda sda_pad_o <= '0'; sda_padoen_o <= '1'; -- to write '1' to sda sda_pad_o <= '0'; -- '0' or '1' doesn't matter sda_padoen_o <= '0'; 2. however it should also be possible to do the following if you directly connect your in/output to a QUARTUS BIDIR pin in your vhdl file port ( .. .. sda_pad_io : inout std_logic; -- i2c data line in/output ); -- in Quartus graphic editor, add a BIDIR pin. -- connect sda_pad_io directly to your BIDIR sda pin. signal sda_in : std_logic; signal sda_out : std_logic; -- read input sda_in <= sda_pad_io; -- write output -- sda is open collector or open drain, we never drive a '1' sda_pad_io <= '0' when sda_out='0' else 'Z';
