10 years agoI want to use own tool chain, how could i install new too chain in the DS-5?
Where is the place I can add the new tool chain from the DS-5? I wanted to use the MinGW gcc compiler. Pls help ! I am using window 7 operating system with 15.0 Soceds.
10 years ago --- Quote Start --- Great ! Where i can select the tool chain? --- Quote End --- hi ths had been mentioned before, you right click at your project tree, then go to properties, c++ than you may see a tool chain column.. just select the new tool chain. remember to rebuild everything.!
