10 years agoI want to use own tool chain, how could i install new too chain in the DS-5?
Where is the place I can add the new tool chain from the DS-5? I wanted to use the MinGW gcc compiler. Pls help ! I am using window 7 operating system with 15.0 Soceds.
10 years agoIf you with window environment try this guide.. this tool will help you to set the environment in the window and include the DS-5 tool path
"http://www.mingw.org/wiki/howto_install_the_mingw_gcc_compiler_suite" easier than A B C...
