I want to design bcd to decimal decoder using structural style. I did it successfully but the problem when I simulate it in Modelsim it does not meet with the truth table.
The truth table:
Input (ABCD) Output
0000 =>0111111111
0001 => 1011111111
0010 => 1101111111
0011 => 1110111111
library ieee;
use ieee.std_logic_1164.all;
entity nandg1 is
port(A,B,C,D: in std_logic;
y: out std_logic);
end nandg1;
architecture df of nandg1 is
begin
y<= (a nand b) nand (c nand d);
end df;
library ieee;
entity notg is
port(x: in std_logic;
xbar: out std_logic);
end notg;
architecture df of notg is
begin
xbar<= not(x);
end df;
library ieee;
entity nandg is
Y0,y1,y2,y3,y4,y5,y6,y7,y8,y9: out std_logic);
end nandg;
Architecture df of nandg is
component notg
port (x : in std_logic; xbar : out std_logic);
end component;
component nandg1
port (a,b,c,d : in std_logic ; y : out std_logic);
end component;
signal abar,ain,bbar,bin,cbar,cin,dbar,din: std_logic;
begin
A1: NOTG port map (A,Abar);
A2: NOTG port map (Abar,Ain);
B1: NOTG port map (B,Bbar);
B2: NOTG port map (Bbar,Bin);
C1: NOTG port map (C,Cbar);
C2: NOTG port map (Cbar,Cin);
D1: NOTG port map (D,Dbar);
D2: NOTG port map (Dbar,Din);
L0: NANDG1 port map (Abar,bbar,cbar,dbar,y0);
L1: NANDG1 port map (Ain,bbar,cbar,dbar,y1);
L2: NANDG1 port map (Ain,bin,cbar,dbar,y2);
L3: NANDG1 port map (Ain,bin,cbar,dbar,y3);
L4: NANDG1 port map (Abar,bbar,cin,dbar,y4);
L5: NANDG1 port map (Ain,bbar,cin,dbar,y5);
L6: NANDG1 port map (Abar,bin,cin,dbar,y6);
L7: NANDG1 port map (Ain,bin,cin,dbar,y7);
L8: NANDG1 port map (Abar,bbar,cbar,din,y8);
L9: NANDG1 port map (Ain,bbar,cbar,din,y9);
end df;
- Abe
Change the 4-input NAND implementation as it is incorrect. Use the following and then check your BCD to Decimal ckt.
library ieee; use ieee.std_logic_1164.all; entity nandg1 is port(A,B,C,D: in std_logic; y: out std_logic); end nandg1; architecture df of nandg1 is begin --y<= (a nand b) nand (c nand d); y <= not (a and b and c and d); end df; - AnandRaj_S_Intel
Hi ab4,
The changes proposed in my previous post should work. Which also communicated in private forum message.
Attaching the simulation output for forum users.
you can copy past the code from my post or from Abe post and try.
Anand
- AnandRaj_S_Intel
Have you implemented 4input NAND gate in entity nandg1?
should be like y<= (a nand b) or (c nand d);
Also check portmap L2.
- ab4
Mr. Raj I did the amendment but the outputs still dose not meet the truth table.
- Pvand1
Does the gate do what you expect when simulating? What is your expectation of the output and where do you think the simulation of one gate is wrong?
