21 years agoI need to know NIOS2 CPU utilization
hello experts, My problem is, that I would like to measure NIOS2 CPU utilization (CPU load) in uClinux under different applications running. Maybe, there already exist some application in uClin...
21 years agohello Scott,
thank you for answer, I investigated more your idea and found following: - /proc/vmstat does not contain info about cpu utilization, I think it highly depends on target system (NIOS, PC,..), even more there exist no application "vmstat" as in normal linux (I tried it in cygwin, and there it works) - but I went through all /proc system report files and found, that /proc/stat produces required info abt CPU utilization on the first line identified by "cpu" keyword - ok I told to me - try to make app, which will extract this line and compute CPU usage - this was succesfully done, but the results are not so good, because: - I think the time consumed by idle and user(system) apps. which is indicated in /proc/stat increases (and also decreases) very very slowly, when another strong process starts (or stops) to have heavy load on CPU. In my example I had CPU usage at about 2 or 3 % in idle state, when I ran heavy IP communication, then NIOS2 CPU usage raised to 95 % but after abt. 5 minutes!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif which is of course impossible delay time for any testing.. maybe there is some settings for kernel to force him to measure more precisely, but I do not believe this.. ?? - I also tried my small application under cygwin in normal PC and it also seems to have a great lag (the current CPU usage value looks like to be averaged in long time - for ex. in one minute) - ok, now I have decided to follow my first idea with my own special application for measuring CPU usage, I will see, but I believe in succes http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif or another ideas?
