15 years agoI need some help of creating shared ddr sdram memory
Hi, everyone:), My system is like this : Using NEEK, I created 2 processors both running in the ddr sdram. Processor1's reset vector offset is 0x100 and exception vector offset is 0x120. Proce...
15 years agoYes. If I can use multiple semaphores,then it will work well because that's a generic producer/consumer problem.
However, different from semaphores, Mutex can only be released by the one who lockes it . So mutex can be used to protect the shared memroy ,howerver it can not be used to coordinate different task of different processors, in my opinion:(
