15 years agoI need some help of creating shared ddr sdram memory
Hi, everyone:), My system is like this : Using NEEK, I created 2 processors both running in the ddr sdram. Processor1's reset vector offset is 0x100 and exception vector offset is 0x120. Proce...
15 years agoHi, BadOmen,
Thank you for your reply. I am very familiar with the example you provided. Though it created a hardware mutex, it doesn't use it.All the communicaiton happens using the mailbox. I will check the mailbox driver anyway:) It seems that there is no easy way to use mutex as convinent as mailbox. However, mutex should be faster:0
