15 years agoI need some help of creating shared ddr sdram memory
Hi, everyone:), My system is like this : Using NEEK, I created 2 processors both running in the ddr sdram. Processor1's reset vector offset is 0x100 and exception vector offset is 0x120. Proce...
15 years agoThank you for everyone's information.
So I think tight coupled memory would be a good choice .However, I wonder why I should use the dual-port mode? If I have 2 processors , maybe configuring as dual-port mode is better because I can connect them to each processor. However, if I have more than 2 processors and I want to have a common shared memory, I think dual-port mode is not necessary at all and I should connect all of the processors to the common slave of the memory and use mutex to coordinate the access.Right? :D;)
