15 years agoI need some help of creating shared ddr sdram memory
Hi, everyone:), My system is like this : Using NEEK, I created 2 processors both running in the ddr sdram. Processor1's reset vector offset is 0x100 and exception vector offset is 0x120. Proce...
15 years agoDear BadOmen,
Thanks for your explanation. I think it makes no sense to have a cacheable shared memory between processors,right? So if I understand correctly, I only have the following 3 choices: 1. Remove the data cache; 2.Use tight coupled memory; 3. Use regular on chip memory or other memory(e.g., SDRAM,SRAM) and use nono-cacheable instructions(like IOWR/IORD or remap the memory as uncacheable as you said) Am I right? Then I think I will see how much resource do I have and choose between choice 2 and choice 3 :)
