15 years agoI need some help of creating shared ddr sdram memory
Hi, everyone:), My system is like this : Using NEEK, I created 2 processors both running in the ddr sdram. Processor1's reset vector offset is 0x100 and exception vector offset is 0x120. Proce...
15 years ago1. Thank you for 'Daixiwen' 's answer. Right. If I remove the data cache, it works well.
2.For 'dsl',I am always feel confused about the difference between tightly coupled memory and the normal on-chip ram. Tighly coupled memory need to be connected to the tight coupled master port of the cpu while the normal on-chip ram can be connected directly to normal master port.Right ? Can I use the normal on-chip ram as the shared memory in my design? Thanks
