21 years agoI have problem with functional simulation with
In the tutorial it says In Quartus, there are two types of simulation. 1) Functional 2) Timing For Functional, you do not need a schematic. Functional means there are zero delays...only...
21 years agoNow I know what is wrong. The tutorial is not so clearly. Man must do Simulator tool, click on the Generate funtional simulation netlist, then do start simulation.
But then I get another problem. I give CLOCK 20.8ns period to clk, give 0-40ns force low(0) to reset_b, give clock 400ns period and 200ns phase to PBSwitch. Then I do the start simulation. I get output of Led is "1111". It does not change. It should be output like "1111","1110","1101".... Do you know what is wrong with my vector wave form?
