20 years agoI can't load my NIOS II application
Hi, When I run debug (custom board), IDE writes: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused ...
20 years agoThank yuo for yours suggestions:
hippo - the pof is on EPCS4, when I try load sof by flash programmer, the same situation, than when I try debug application (Resetting and pausing target processor: FAILED Leaving target processor paused) dannyjacobs - I think, I downoloaded the right NIOS in my board. Clock freq = 33.33MHz, Reset Nios pin is no drive (with default value VCC). About memory - I'll try use only OnChip memory and smallest NIOS application. Thank you
