20 years agoI can't load my NIOS II application
Hi, When I run debug (custom board), IDE writes: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused ...
20 years agoHi,
Make sure you downloaded the right NIOS into your board. Make sure the clock-frequency is not too high, else you could having problems with your memory Cheers, Danny
