20 years agoI cann't use "getchar()"
I add one section code to hello_small_word.c. But it cann't building.
# include "alt_types.h"# include <stdio.h># include <unistd.h># include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h"# include <string.h> int main (void) __attribute__ ((weak, alias ("alt_main"))); int alt_main() { //alt_u8 c; int c; printf("Hello from Nios II!\n"); // while(c = nr_uart_rxchar()) c = getchar(); while (c = 'a') { printf("I receive A from my board \n"); } return 0; // exit(0); }2 Replies
what is the error masege that you get?
and what is the meenning of while(c='a') this will always be true did you ment (c=='a') - Altera_Forum
The stdout/stdin/stderr devices are initialized in alt_main by the following code: alt_sys_init (); /* * Redirect stdout etc. to the apropriate devices now that the devices have * been initialised. This is only done if the user has requested that the * channels been directed away from /dev/null - which is how the channels * are configured by default. Making the call to alt_io_redirect conditional * allows this function to be excluded from optomised executables when it * is unecessary. */ if (strcmp (ALT_STDOUT, "/dev/null") || strcmp (ALT_STDIN, "/dev/null") || strcmp (ALT_STDERR, "/dev/null")) { alt_io_redirect (ALT_STDOUT, ALT_STDIN, ALT_STDERR); } /* Call the C++ constructors */ _do_ctors (); In your program, you detele these codes, so it can't support any stdout/stdin/stderr operation. best regards, David
