FZhan39
7 years agoI Can not run my Nios II program, because of "Project does not have an ELF file"
Hello,friends there is a problem when i used Nios II, "project does not have an ELF file, Please make sure project has been built successfully", Do anyone kown this issue? Thanks
- 7 years ago
8192 Bytes is small for an application, please let me know what device family you are using? I normally start with 64000 Bytes and see if the application will fit or not.
FZhan39
7 years ago
