13 years ago"HW_MUL_SUPPORT" in Nios2-Linux with MMU supported distribution
All,
Can anyone please explain how enabling/disabling "hw_mul_support" in Nios2-Linux with MMU supported distribution works? I'm using embed multiplier supported SOPC system. When I tested multiplication operation using this system with enabling and disabling HW_MUL_SUPPORT, I did not observe any difference between them. Enabling this support in make menuconfig enables "-mno-hw-mul" flag at compile time. Does it create different multiplication instruction at compile time for multiplication operation? I want to trace the assembly instructions that are used for both enabled/disabled support. Can anyone help me? Thanks in advance! Regards, Harshil2 Replies
--- Quote Start --- Enabling this support in make menuconfig enables "-mno-hw-mul" flag at compile time. Does it create different multiplication instruction at compile time for multiplication operation? --- Quote End --- Yes. I think there is a separate setting for kernel and apps though. If you are compiling your app separately from uClinux-dist, you'll need to set the flag yourself. --- Quote Start --- I want to trace the assembly instructions that are used for both enabled/disabled support. Can anyone help me? --- Quote End --- Look at the disassembly using nios2-linux-gnu-objdump (man objdump). - Altera_Forum
Thanks "ykozlov"! Thanks for the response. :)
