21 years agoHTTP server demo not accepting connections
I've been trying the HTTP server demo, and haven't had any luck getting the demo board to accept connections from outside. I built it according to the directions in kits/nios2/component...
19 years ago --- Quote Start --- originally posted by monkeyboy@Mar 23 2005, 06:08 AM the message:
[eth_drv_ioctl] warning: driver can't set multi-cast mode
is normal, since the lan91c111 driver doesn't support multicast unless explicitly enabled. this shouldn't be related to the problem that you're seeing.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=5617)
--- quote end ---
--- Quote End --- Could you tell me how can I enable multicast support for LAN91C111, thanks.
