21 years agoHTTP server demo not accepting connections
I've been trying the HTTP server demo, and haven't had any luck getting the demo board to accept connections from outside. I built it according to the directions in kits/nios2/component...
21 years agoI may be able to hold out some hope to you. There was a posting recently on the eCos mailing list which describes something that sounds very like the problem you are describing: http://www.spinics.net/lists/ecos/msg27032.html (http://www.spinics.net/lists/ecos/msg27032.html)
Following this, it seems that a fix is to change the definition of sockaddr_inarp in packages\net\bsd_tcpip\current\include\netinet to:struct sockaddr_inarp {
u_char sin_len;
u_char sin_family;
u_short sin_port;
struct in_addr sin_addr;
struct in_addr sin_srcaddr;
u_short sin_tos;
u_short sin_other;
u_char pad;# define SIN_PROXY 1
}; i.e. add 14 bytes of padding to the end. Hope that helps!
