21 years ago
Hpw do I change the startup adr of an app
Hi
I tried writing about this before. Hope someone can help me.
I have a simple program. I want to change the startup adr of my program from 0x1000000(SDRAM base adr) to for an exsample 0x1100000. I have tried to define my own custom linker script in the system library.
Here below I have copied in the changes I made to the default linker script
MEMORY
reset : ORIGIN = 0x00000000, LENGTH = 32
ext_flash : ORIGIN = 0x00000020, LENGTH = 8388576
ext_ram : ORIGIN = 0x00800000, LENGTH = 1048576
epcs_controller : ORIGIN = 0x00900000, LENGTH = 2048
sdram_UNUSED : ORIGIN = 0x01100000, LENGTH = 32
sdram : ORIGIN = 0x01100020, LENGTH = 15728640
/* Define symbols for each memory base-address */
__alt_mem_ext_flash = 0x00000000 ;
__alt_mem_ext_ram = 0x00800000 ;
__alt_mem_epcs_controller = 0x00900000 ;
__alt_mem_sdram = 0x01100000 ;
But when I use this script nothing really happens when I starte up the program.
What am I missing???
Can this be done with this script or must it be done with the ELF tools???? If yes how with the ELF tools????
Hope someone can help me since the documentation for this is none existing
Best regards
GreateWhite.DK
    The bootm command is now implemented. You'll also
    need to get the mkimage utility to create the u-boot
    image file. Pre-builts, sources, etc updated at:
    http://www.psyent.com/download (http://www.psyent.com/download)
    I tested by booting a gzipped Microtronix linux kernel
    on the Altera 1C20 devkit board. Result were pretty
    good:
    vmlinux.bin: 1.6 MB (original binary)
    vmlinux.img: 678 KB (gzipped u-boot image).
    BTW: see the README in the mkimage zip file
    for instructions.
    --Scott
    Hi Scott
    Really nice that you have finished it.
    Have gotten my own loader up and running now and it runs super http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    Tried using your u-boot because you get a better compression from your GZip that I get from using my alogoritme.(I only get the 1.6MB to about 900k)
    But when I try starting up the u-boot as instructed in the readme file I get
    U-Boot 1.1.2 (Sep 17 2004 - 16:15:21)
    CPU : Nios-II
    SYSID : 948685d8, Wed Apr 28 05:53:44 2004
    BOARD : Psyent PK-1C20
    *** Warning - bad CRC, using default environment
    So when I get some spare time I will take a more close look at it.
    Thx again for all your help Scott you have many buddy points in my book http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    GreateWhite.DK
    This is normal behavior when the environment has not been saved to flash.
    u-boot supports environment variables. These variables are simply name-value pairs.
    If you execute the &#39;printenv&#39; command, you should see something like:
    stdin=serial
    stdout=serial
    ipaddr=192.168.2.21
    You can add variables to the u-boot environment using the &#39;setenv&#39; command.
    For example, to set the environment variable &#39;netmask&#39; to &#39;255.255.255.0&#39;:
    ==> setenv netmask 255.255.255.0
    When u-boot starts up, it trys to read saved environment variables from
    a configured address. In the case of the PK1C20 configuration, it uses the
    flash sector at 0x0000_3000. The environment is stored as a 32-bit CRC,
    followed by strings formatted as "name=value\0". If the CRC is good,
    u-boot uses the variables from flash, otherwise it uses a set of default
    variables that are created at compile time.
    To save your environment to flash (and prevent subsequent warnings at
    startup), just use the &#39;saveenv&#39; command. Provided that you flash programming
    implementation is correct, u-boot will copy the variables to flash and write
    the 32-bit CRC.
    The enviroment variables are quite handy for storing things such as serial
    numbers, default ip addresses, etc. They may also be used in commands
    and u-boot scripts. For example:
    ==> setenv serverip 10.0.41.40
    ==> ping $serverip
    A more complicated example would be to set the bootcmd variable to load a
    kernel image via tftp, then boot the kernel. The bootcmd variable can be
    configured to automatically run at startup after a configured delay (in this
    case 5 seconds):
    ==> setenv bootcmd "tftpboot 800000 linux.img; bootm 800000"
    ==> setenv bootdelay 5
    ==> saveenv
    Anyway, there&#39;s a long-winded description ;-) of some things you can do with
    the environment.
    --Scott
