22 years agoHpw do I change the startup adr of an app
Hi I tried writing about this before. Hope someone can help me. I have a simple program. I want to change the startup adr of my program from 0x1000000(SDRAM base adr) to for an exsample 0...
22 years agoYou can set the starting address of the .text segment with the -Ttext
linker command line option. For example: ld -Ttext 0x01100000 ... Alternatively, you can use objcopy with any number of various command line options (e.g. --adjust-vma). The actual __entry__ point can be set in the linker command file. In many implementations: ENTRY(_start) For example, the u-boot monitor uses the following linker command file contents, with the command line option -Ttext 0x018e0000. Regards, --ScottOUTPUT_FORMAT("elf32-littlenios2")
OUTPUT_ARCH(nios2)
ENTRY(_start)
SECTIONS
.text :
cpu/nios2/start.o (.text)
*(.text)
*(.text.*)
*(.gnu.linkonce.t*)
*(.rodata)
*(.rodata.*)
*(.gnu.linkonce.r*)
. = ALIGN (4);
_etext = .;
PROVIDE (etext = .);
/* CMD TABLE - sandwich this in between text and data so
* the initialization code relocates the command table as
* well -- admittedly, this is just pure laziness;-)
__u_boot_cmd_start = .;
.u_boot_cmd :
*(.u_boot_cmd)
. = ALIGN(4);
__u_boot_cmd_end = .;
/* INIT DATA sections - "Small" data (see the gcc -G option)
* is always gp-relative. Here we make all init data sections
* adjacent to simplify the startup code -- and provide
* the global pointer for gp-relative access.
_data = .;
.data :
*(.data)
*(.data.*)
*(.gnu.linkonce.d*)
. = ALIGN(16);
_gp = .; /* Global pointer addr */
PROVIDE (gp = .);
.sdata :
*(.sdata)
*(.sdata.*)
*(.gnu.linkonce.s.*)
. = ALIGN(4);
_edata = .;
PROVIDE (edata = .);
/* UNINIT DATA - Small uninitialized data is first so it's
* adjacent to sdata and can be referenced via gp. The normal
* bss follows. We keep it adjacent to simplify init code.
__bss_start = .;
.sbss :
*(.sbss)
*(.sbss.*)
*(.gnu.linkonce.sb.*)
*(.scommon)
. = ALIGN(4);
.bss :
*(.bss)
*(.bss.*)
*(.dynbss)
*(COMMON)
*(.scommon)
. = ALIGN(4);
_end = .;
PROVIDE (end = .);
/* DEBUG -- symbol table, string table, etc. etc.
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
.stab.excl 0 : { *(.stab.excl) }
.stab.exclstr 0 : { *(.stab.exclstr) }
.stab.index 0 : { *(.stab.index) }
.stab.indexstr 0 : { *(.stab.indexstr) }
.comment 0 : { *(.comment) }
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
.debug_info 0 : { *(.debug_info) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
