9 years agoHPS t o FPGA access time measuring
Hi everybody,
I am currently playing around with the Cyclone V SoC Development board. I have a QSys system running resembling the Golden system reference design apart from the fact that the h2f_axi_clock is controlled by a PLL residing on FPGA side. The h2f_axi_clock is 50 MHz in my case. I have an IP test (with many registers) up and running according to the GSRD and connected directly to H2F_axi_master. I used the Linux example to run a Linux (3.7) application on the HPS. From within the application I can write to and read from my IP test in the FPGA, the memory address range is mmaped to the linux user space for this purpose. Now the question: The time taken to lauch 2 read (or write ) access from an application to my IP registers was mush more than expected (we should have a bandwith of 3.5 GHZ/s I think) : According to signal tap (by tracking the chipselect signal): 1 read access takes only 40ns , (1 write, 20ns) whereas between 2 read access there is a 320 ns (same as for write access) . And my application is simple: mmap IP address writes 32-bit values to 10 registers and read back results at the end (by storing them in an array of uint32_t : uint32_t IP_reg[10]). read instruction: IP_regs[0]= *((unsigned long *) (map_base + (target & MAP_MASK)+24 ));// (10 accesses such as this one) write instruction: *((unsigned long *) (map_base + (target & MAP_MASK) +24 )) = 1;// (10 accesses such as this one) How can I accelerate several read write accesses to FPGA IPs from the HPS ? Thanks in advance, ---------------------------- My IP interface: mm_avalon Processor : 925 MHz, ARM cortex A9 dual core Board: Altera cyclone V SX SoC1 Reply
Hi Sam16,
I appreciate that this is a late reply, but thought a reply might be better than nothing. I found I would get better access using commands like memcpy rather than individual reads, but I haven't done as careful timing as you. Other options would include setting a pointer, eg ip_regs_base = *((unsigned long *)(map_base + ....); and then you can do: IP_regs[0] = ip_regs_base[0]; and ip_regs_base[0] = 1; to simplify what the compiler might generate. But memcpy is tailored to moving memory quickly and efficiently, so it will use minimal instructions to do the job. Cheers, Simon
