21 years agohowto start debugger with reset ?
I want to start the debugger with resetting the cpu before starting. This is to get a defined behavior of the system as it would be started with poweron. Otherwise each program starts is unde...
21 years ago --- Quote Start --- originally posted by fischer@May 18 2005, 05:16 PM i can manually run this command by ide but it says:
generating markers..., building...,generating markers...
this works, but it's annoying slow !
can the ide simply start an external program,
without trying to rebuild the whole world ! --- Quote End --- Try to hack the checkbox in windows/preferences/rundebug/launching/build if required ... the IDE in that way will not check if the projects are updated... Paolo
